JT data not created when import assembly into teamcenter for NX.
Solution Partner Innovator Solution Partner Innovator
I have some issue where the jt data is not created when import assembly into teamcenter.
Any idea on how to auto create the jt data for asm and the child part once finish import the asm to teamcenter?
Please advices.
Re: JT data not created when import assembly into teamcenter for NX.
You can run refile to create JT's for the component parts (assemblies don't have JT's) after importing is completed.
Evaluating: AW 3.4
