Launch NX without Launching 4TR client
Builder
Builder
Hi
I undertand we can launch NX in managed mode from command prompt wihout launching teamcenter where it does ask for ID/Password.
does any use the NX in that (wihout launching Rich client) so that users can work directly from NX.
TIA
10 REPLIES 10
Re: Launch NX without Launching 4TR client
Yes you can launch NX Native works directly without launching rich client.
Once you launch NX if you want to save files directly to Teamcenter, you can find the Tc icon on the left side if NX integrator is installed and you will be able to login directly from NX environment.
Find the attached snapshot
Best Regards,
Jeethan Rohan
Many experience NX  users already famlier with start the native NX. They do not like the way to start Teamcenter, then start NX from teamcenter.
Honored Contributor
Honored Contributor
I provide the option to run managed NX without TC rich client, for the machine shop, that finds Teamcenter to be intimidating.  Most of our users just launch NX from Teamcenter, even though they don't do much with TC, simply because that's how they were shown from day 1 (before I has the alternative setup)
-Dave
Yes, launching NX through Teamcenter is time consuming and user tend to repeat it. Best way is Nx integration to TC with active workspace.
https://www.youtube.com/watch?v=kK0L4dhCfXk
Best Regards,
Jeethan Rohan
Builder
Builder
@JRT
Thanks a lot, we are moving to TC and many users experienced with other PLM asking they dont need much of TC just NX. our site setup going to be 4-tier client +NX11. can you please add some tips on running integrator. (I have onfigured NX manager from OTW side, i assume you are not mentioning that). while i wait for your reply i will also do some search on google or GTAC
You will likely find your answer in the NX documentation and using the "pim=yes" argument.
https://docs.plm.automation.siemens.com/tdoc/nx/11.0.2/nx_help#uid:index_tcint:id1299396:id1299402:g...
Evaluating: AW 3.4
Most other PLMs work like this way: Start CAD application first, then start PLM system from CAD application.
For Teamcenter, my opinon the best practice is, Start Teamcenter first then start NX from teamcenter.
How to start Teamcenter and NX is not a big issue. Users mainly work foucs on designe and data management.
They will familier with Teamcenter and NX and will love it soon.
Honored Contributor
Honored Contributor
This is what I used, to assit me in getting things setup.
https://solutions.industrysoftware.automation.siemens.com/view.php?sort=desc&p=1&q=How+to+launch+NX+...
Note, the biggest issue I had, was getting it to work with our setup, using Rob Cohon/Gerrit Koelewijn's NXcustom.
-Dave
@nesthome
You are welcome, please refer link provided by @RandyEllsworth
Best Regards,
Jeethan Rohan
