Do you mean
Reply
Solved! Go to solution
Legacy Item creation wizard
Hello All,
We are using TC11.2.1 at the moment and we have an issue with mixup of new Item creation wizard and Legacy ones.
If i use File-->New-->Item, then the new Item creation wizard pops up.
But if i use File --> New --> Design/Part , then the legacy creation wizard pops up.
I tried to customize the stylesheets, but that doesn't change anything.
Any help here, please?
Arun
Re: Legacy Item creation wizard
Hi ArunG,
Please check the Createrendering preference, Dont change the OOTB Stylesheet, but derive your custom stylesheet out of the OOTB Stylesheet.
If that doesn't work, create metacache in the following order
-t delete all
-force
-t generate all
Try again.
Chene
Hi Chene, Thanks for your reply. The changes to the stylesheet reflects only when i use File --> New --> Item.
As i said, when i use File --> New --> Design / Part, then the wizard itself is "Legacy" one and now i don't know how to change this window.
Hi ArunG,
This feature is used by CAD-Part alligment. May be you can take a look at the plugins folder in Portal. you should find something there. Thats all i have at this point. I need time to look into it.
Chene
Solution
Solution
Accepted by topic author ArunG
‎09-05-2016 02:42 AM
I had an Incident Repoert opned to GTAC and they closed it stating that they are aware of this issue and will be fixed in futrue releases (GTAC is not yet sure at which release the fix is available)
