Legacy Viewer
Builder
Builder
Can we set the legacy viewer in TC11? In TC8, viewer iss displaying as tabular view.But in tc11 its showing as a plain sheet.
Re: Legacy Viewer
Can you give us an example of what you're describing? It may be solved by a stylesheet depending on the workspace object selected.
Evaluating:AW 3.2
Re: Legacy Viewer
Builder
Builder
@RandyEllsworth,
Re: Legacy Viewer
What does the Item Master look like in Tc11 after you check it out for edit? Fill-in some of the empty fields on the IM and save/check-in. How does the Item Master look now?
Tip: Look for the "show empty properties" at the end of the sheet.
The OOTB behavior is to show each property/value on a separate line sorted alphabetically (upper-case first then lower case). You can create and add your own stylesheet to display the properties as you see fit.
Evaluating:AW 3.2
Re: Legacy Viewer
Builder
Builder
@RandyEllsworth,
Thanks. I have found one preference which will set the viewer as legacy.
defaultViewerConfig.VIEWERCONFIG=Form.FormViewer
