Lifecycle Viewer measurement
Hi all,
Wondering if anyone knows if you are able to change the units when doing a 3D Measurement within the Lifecycle Viewer application, with License level BASE.  I am trying to change from meters to inches.  I see I am able to do this with higher license levels.
Does anyone know if this can be done with license level BASE?
Any input is appreciated!
Jake
Re: Lifecycle Viewer measurement
Just in case anyone was wondering..
 Once in Lifecycle Viewer with a part opened..  Select file>preferences>Teamcenter Integration.  From within the Teamcenter Integration Preferences dialogue box, select your desired unit of measure from the drop down under "Document Units".  Any parts that are open will have to be reloaded to take effect.
Jake
