Limit data entry in UI for fields not supported by Naming Rules. TC10
All,
In Teamcenter 10 we have a requirement to limit the data entry in certain fields to suit data transfer to third party system.  For example, object_desc on Document object.  Teamcenter length is 240 characters but third party system is 128.  We will be feeding this data to the third party system so we wish to limit the field length for data entry into Teamcenter.
A naming rule cannot be attached to object_desc to achieve this so we need another method.  Was thinking a defining length or mask using stylesheets to overrule the data model would be a way to do this but I cannot see how.  Is this possible?
Dave
