Lost cofiguration
Builder
Builder
Dear all,
We have installed teamcenter 11.2 for the first time. After installing corporate server and some additional features under configuration1 we run tem.bat as administrator and created configuration2 to install BMIDE. but after doing this We can not find configuration1 and related features to edit.
But still we have access to Teamcenter rich client and everything works well
I will thank you if anyone can help us to solve the problem
Sina Shojaee
Re: Lost cofiguration
Hopefully, you installed configuration2 to a separate location than configuration1. In the Rich Client, Help > About, then click the "More Information..." link which will open a new dialog showing the location of TC_ROOT and TC_DATA. Look at TC_ROOT\install for the configuration.xml of configuration1. If it says configuration2 then you've overwritten configuration1. You can validate this by looking at previous configuration.xml files in the TC_ROOT\install directory.
Builder
Builder
Thank you Randy, I found my main tem.bat file in TC_Root\install and there was another one for BMIDE. I uninstalled that one and changed the adress in tem shortcut in all programs.
Sina Shojaee
