MS Office integration: How to save as an Item instead of dataset ?
From the Teamcenter menus in MS Office, I can save MS Office doc as Dataset. How to save it as an item ?
Re: MS Office integration: How to save as an Item instead of dataset ?
From integration menu you should create item and then save file as a dataset into this item.
Best regards
Bernard
Best regards
Bernard Pacula,
CAMdivision Sp. z o.o.
Consultant PLM/System Architect
