Manage & View 3D to 2D relation in Teamcneter
Siemens Genius Siemens Genius
Siemens Genius
Hello Experts,
We have decided to use seperate items for 2D & 3D data in our organisation (Catia V5). 2D by default contains a DWG_Link (2D to 3D Link) with associated 3D.
However, when i open my 3D data, i have to look in Impact Analysis" to look for drawing references or use MML browser.
My requirement here is i need to know all the 3D in my EBOM that has 2D in Teamcenter. Are there any ways to do this? I thought of introducing a new Boolean property on Item Revision like Drawing Exists=true/false. But the pain is if user chooses wrong value, then it would still be misleading.
Any help here, please? Thanks
Kind Regards,
Arun Kumar G
6 REPLIES 6
Re: Manage & View 3D to 2D relation in Teamcneter
Siemens Genius
Here More Information in the attached image:
Primary Object is "2D Dataset"
relation type is "catiaV5_DWGLink"
secondary Object is "3D Item Revision"
My 2D is configured to show catiaV5_DWGLink in the pseudofolder for Drawing Datasets in Teamcenter Preference.
But how do i configure 2D Dataset / Item Revision to show up in my 3D Item Revision?
Siemens Genius
I see Four Properties in Teamcenter namely: fnd0Drawings, fnd0ConfiguredDrawings, Drawing Of, Drawing Using. But all these fields are blank for both Catia Drawings as well as 3D.
Guess these fields are populated only for NX datas :-(
Did you find the solution for this issue?
Do you found any solution for this topic??
Even we faced this issue with Catia Integration. Only solution is to define custom Run time attribute to store secondary object or define a custom relation and add a post action on relation to populate custom relation from Secondary to primary.
Thanks for the info. We are also thinking in the same direction.
