Manufacturing Process Planner missing
I have installed TC RapidStart 11.2.0 and even tried with 11.2.2, but in both versions the MPP application is missing. Even if I go to "add more applications", it's not there to choose from, as if it isn't installed.
Is this a limitation of TC RapidStart or is there another menu where MPP can be added/activated? Note that MPP is enabled in my license.
Thanks.
Re: Manufacturing Process Planner missing
This was an error on my part, MPP and a bunch of other features are not part of RapidStart.
Solved.
