Map Teamcenter Owner_id to NX
Hi there,
Please help to solve my attribute mapping problem.
I have made a custom item type in BMIDE and custom properties (c3d_description_2, and c3d_material). Then I have the following mapping file:
{ Dataset type="UGMASTER"
"DB_PART_NAME" : Item.object_name /write_once /description="Part Name"
"DB_PART_DESC" : Item.object_desc /write_once /description="Part Description"
DESCRIPTION_2: ItemRevision.GRM(IMAN_master_form,C3D_partRevisionMaster).c3d_description_2 /master=cad /description="Description_ENG"
C3D_MATERIAL: ItemRevision.GRM(IMAN_master_form,C3D_partRevisionMaster).c3d_material /master=cad /description="Material"
CHECKED_OUT : checked_out /master=iman /description="Checked Out"
CHECKED_OUT_BY : checked_out_user /master=iman /description="Checked Out By"
OWNER_ID : owning_user.user_id /master=iman /description="Owning user id"
The custom properties are (c3d_description_2, and c3d_material) working well, but the CHECKED_OUT, CHECKED_OUT_BY, OWNER_ID in NX shows <No Value>
Anybody have an idea why NX not whows these properties?
Thank,
Laszlo
Re: Map Teamcenter Owner_id to NX
I don't know your exact syntax but this will get the conversation started...
The checked out and checked out by could be null so you'll need to allow null with "/allow_null_value" switch. The owning_user may work by itself without the user_id (similar to checked_out_user) but more likely will require the user_name. Not sure what you're going after for CHECKED_OUT (date, logical[y/n])?
For your custom Item type...
{Dataset type ="UGMASTER"
# Global (generic) declarations
OWNER_ID: owning_user.user_name ...
CHECKED_OUT_BY: checked_out_user.user_name ...
{Item type ="C3D_Item"
# Properties specific to this Item type
Thanks for the answer. First of all, I would like to use the owner_id to replace the attribute "designer" what we use before the Teamcenter. My idea the drawing shows the owner_id of NX model in the title block as "designer" All other Checked-out, and checket-out-by currenly less important, and I think it will work similar to owner_id.
So based on your suggestion I made a change in my mapping file:
CHECKED_OUT : checked_out /master=iman /description="Checked Out" /allow_null_value
CHECKED_OUT_BY : checked_out_user /master=iman /description="Checked Out By" /allow_null_value
OWNER_ID : owning_user.user_id /master=iman /description="Owning user id" /allow_null_value
{ Item type="C3D_part"
Still <No Value> in NX.
Try: owning_user.user.user_id
user_id is a property of the User object.
No success, still <No Value> :(
Try :
Item.owning_user.person.user_name
or
ItemRevision.owning_user.person.user_name
Sorry guys, it was my mistake, the original mapping is working. Something was wrong with my nx template file.
