Map dataset owner user
Hi there,
Anybody knows how to map attributes from UGPART? I've tried to map Owner user like the syntax below but it doesn't works.
"Owner_DWG" : UGPART.owning_user.user_id /master=iman /description="Owner_DWG"
Bauler
NX 12.0.1 | TC 11.4
Re: Map dataset owner user
Try this...
{ Dataset type="UGPART"
"Owner_DWG" : owning_user.user_id /master=iman /description="Owner_DWG" /allow_null_value
Evaluating: AW 3.4
@RandyEllsworth
In sameway how to bring the workflow attributes like reviewed by , checked by and approved by..
Thanks.
