Mapping Attributes for Solidworks Integration
Hi guys,
I've got NX and Teamcenter integration in my TC Rapis Start environment.
I've some attributes mapped for UGMASTER and want the same ones also to be mapped to SWPRT as well.
I tried to copy the ones under UGMASTER to SWPRT, SWASM, SWDRW but I did not see them in the parts I created in Solidworks as attributes.
What else should I do?
Cem
Re: Mapping Attributes for Solidworks Integration
Hi Cem,
Here is snip from my SWIM client. It shown how to declare some of the attributes from my TcRS forms into SolidWORKS. So basically all you need to do to get your mapped attributes to display is define them in the SWIM.xml file.
Hope this helps,
ion
