Mapping OS Name
Hi there,
Anybody knows how to map OS Name? I tried to use that syntax:
"Owner_OSNAME" : Item.owning_user.owning_user /master=iman /description="Owner_OSNAME"
... and:
"Owner" : Item.owning_user.user_name /master=iman /description="Owner"
So it doesn't works.
Teamcenter 11.4 | NX 12.0.1
4 REPLIES 4
Re: Mapping OS Name
What is the property name in NX? You are mapping an existing NX property to a TC property.
Jamie Griffis | Teamcenter Architect | Applied CAx, LLC
Re: Mapping OS Name
I've tried to get OS Name from Teamcenter Organization. So on the syntax Owner are the property name in NX.
Re: Mapping OS Name
"Owner" is the property in NX that will map to Item.owning_user.user_name.
Does the property named "Owner" exist in your NX files? Do you get any errors or this just doesn't work?
Re: Mapping OS Name
Enter the query builder and select a query for items or revisions.
Now set the display settings as shown below.TcQueryDisplaySettings.PNGQuery Display Settings
Search for the owning_user attribute and double-click it to get the list of its attributes.
Search for os_username, which should hold the information of the field you mentioned.
"Owner_OSNAME" : owning_user.os_username /master=iman /description="OS name of owning user"
The above should then do the trick.
Employees of the customers, together we are strong ;)
