Material and Weight Properties in Teamcenter
Hi guys,
I've defined MyMaterial and MyWeight properties to my ItemRevision.
Imported those attributes and added them to stylesheet so that I can see them under Summary in Teamcenter Rich Client.
I also put them into the drafting sheet automatically, everything works for now.
What I want to do is, if I assign a material inside NX, I want the material name to override MyMaterial's value. And also the calculated weight to override MyWeight attribute that I defined.
After assigning material in NX it's attribute becomes NX_Material, and weight is NX_Mass.
How can I make MyMaterial get NX_Material's value? (same for MyWeight)
Cem
Re: Material and Weight Properties in Teamcenter
You could use an expression to read the OOTB attribute and write it to your custom one.
Employees of the customers, together we are strong ;)
Sounds like a good idea.
Can you give a small example?
Also should I put that expression in the model template or drafting template?
To ensure that it is always done automatically?
Cem
I would place them into the model template, since the model attributes are inherited by the drawing anyways and the weight is calculated in the model.
ug_setPartAttrValue("MyMaterial",ug_askPartAttrValue("NX_Material"))
ug_setPartAttrValue("MyWeight",ug_askPartAttrValue("NX_Mass"))
I guess I should update the mapping to "/master=both" right.
Anything else needs to be taken care of?
Cem
Generally I always have master set to both, since it doesn't make sense to have to switch applications to fill in attributes ;)
I don't think there is more to take care of, you will have to test if the update is working as expected, since prior to NX 8 there have been problems with this.
Thanks Stefan, it worked beautifully!
Cem
