Ms Office integration for AWC
We wanted to view and edit Microsoft Office files directly in Active Workspace. Is there any document available for it?
Teamcenter version : TC10.1.7
AWC version : 3.4.1
Br,
Rupesh
8 REPLIES 8
Re: Ms Office integration for AWC
You can view/edit AW in MSO using the Addin but I don't think you can view/edit MSO directly in AW (see SFB-Teamcenter-10052).
Evaluating: AW 3.4
@rupeshs
Please see the reference documentation below for more information on using Microsoft Office Online which is required to view MSOffice documents in the universal viewer in AW3.4.
reference documentation: https://docs.plm.automation.siemens.com/tdoc/aw/3.4/aw_html_collection/#uid:xid1446499
Easily view and edit files
You can view and edit Microsoft Office documents with the universal viewer and Microsoft Office Online without having to download and install anything. However, your administrator must set up and configure Office Online before it can be used.
Note: This functionality requires Teamcenter 11.4 or later.
Installation documentation:
There are 2 pieces of the installation:
1.         Installing the Microsoft Office Online Server: https://docs.microsoft.com/en-us/officeonlineserver/deploy-office-online-server
2.         Installing the Teamcenter Office Online Server: Specifically in Chapter 9: Setting up Teamcenter Office Online.
https://docs.plm.automation.siemens.com/data_services/resources/tc/11.4/PDF/tdoc/en_US/pdf/deploying...
Rafa
Thanks Rafa! It seems we have to wait till we upgrade to TC11.4 since we have TC10.1.7 running.
Br,
Rupesh
Hi rafa, what is sponsor user id while configuring tcoos in deployment center.
I have not been able to load uniersl viewer after doing all the required configurations.
Also, i see thwt tc oo web service is also not loading. For eg my url is http:\hostname\tcooweb\api\wopi
This url returns a error, saying unable to access this page.
Hi Rupesh,
You can view and edit Microsoft Office documents with the Active Workspace 3.4- universal viewer capability and Microsoft Office Online without having to download and install anything, Not require any client installation.
Minimum version of Teamcebter and Active workspace:- Teamcenter 11.4 Active Workspace 3.4
It will required to setup 2 pices primerly.
1. Installing Microsoft Office Online Server, follow this URL (Prefer windows 2016 if possible) https://docs.microsoft.com/en-us/officeonlineserver/deploy-office-online-server
2. Install Teamcenter Office Online https://docs.plm.automation.siemens.com/tdoc/tc/11.4/help/#goto:plm00053:xid1445551
* Deployment Center 3.0
Teamcenter Office Online installation will require to install these two feature in Teamcenter/Active workspace serevr- Teamcenter office online & Teamcenter office online webs ervice.
These features can oly be installed using DC, its not available through TEM installer.
Good luck Alok
The currently available version of Deployment Center is 2.2. 3.0 is not available to the Community yet.
Evaluating: AW 3.4
Awesome..!'
Thank you very much for reminding this point, Deployment Center 2.2. can do that job
Cheers..!
Alok
