Multiple Sign-Off's in the Ad-Hoc Workflow.
Folks,
I would like to understand if there is a possibility of adding multiple people for the sign-off's in Ad-Hoc. The key difference is  number of people to sign-off may differ from one Workflow Process to another. For E.g
00445718/002 - Requires three signoff's (People to sign-off can be from one or multiple group)
00445719/001 -Requires one signoff
00445720/006 -Requires two signoff  (People to sign-off can be from one or multiple group)
Would appreciate any help in this regard.
Cheers !
Teamcenter 10.1.3
TC Visualization 10.1.3 (Custom Patch)
NX:8.5 | NX 9.02 | Catia V5 R2012 | AutoCAD 2015 | In-Context Editor |
Re: Multiple Sign-Off's in the Ad-Hoc Workflow.
Probably the simplest and ootb solution would be:
  1. Set your process template to accept one reviewer and quorum set to ALL.
  2. Initiate process.
  3. Before selecting the signoff team, send the job to process viewer and go in edit mode. This will need proper access (initiator or DBA)
  4. Once there, change the select-signoff-team's configuration to accept however number of reviewers and adjust quorum accordingly.
  5. Save and select your team.
Drawback is that you have to do this every time when you have this deviation.
Advantage is that, this is ootb solution.
You can always write your custom handler to do this.
Thanks and Regards
Yogesh Fegade
Fegade,
Thank you for your response, Looks like we have to develop a custom handler as you mentioned as this scenario is almost every day and not all the WF initiaters have the ability to modify the WF. So Custom handler is the way to go.
Cheers !
Teamcenter 10.1.3
