.NET Server Manager Admin Console
Dear Listers,
In the server manager admin console that runs on 8085 port where it dsiplays how many users are logged in and how many servers are assigned etc... is there any configuration that will enable this as when I launch the servermanager url with the port 8085 it does not work . I have the service of the server maanger running ....
What configration needs to be enabled that will bring this interface on an .NET platform
Vilas
4 REPLIES 4
Re: .NET Server Manager Admin Console
Hello, try to log:
http://server-name:<port>/tc/admin
as far as I remember port 7001 is used by default
Would the default password be manager/ manager?
No, for .NET this will be the user's login and password from which the service is running
The default for .NET is usually admin/admin. For J2EE it is manager/manager.
Evaluating: AW 3.4
