NX Integration, Teamcenter install
I wish to setup Teamcenter 11 for use with the NX integration only. What Teamcenter components need to be installed for this. I plan on using MYSQL as the database server. Is there any preconfigured options that will work for this?
Re: NX Integration, Teamcenter install
As far as I know, MYSQL is not compatible as a database server for Teamcenter. You need to use MSSQL, IBM DB2 or ORACLE
http://m.plm.automation.siemens.com/en_us/Images/Tc11-2PlatformMatrix_tcm1224-233016.xlsx
