NX PCB Integration with Teamcenter
I have installed NX12.0.2 and patched with maintanance pack 7.Then I updated NX with nx-pcb-12.0.2.02 the latest pcb update for NX12.0.2.However, I have problem reading and writing IDX files from and to teamcenter.For IDX file I use the EDAIdf dataset that includes idx file but when in NX PCB application, I use command "Import ECAD model",I get an error that dataset was not found under that Item revision.In addition,when I select  "Export ECAD model" it complains that Item/revision not found(it does not matter if I select a new Item or the current one,in both cases it cannot find Item/Revision).Can anyone help me with these problems.Many thanks in advance.
Best regards
/Navid
