NX drawing to PDF conversion
Hello All,
I am having trouble to get the drawings as pdf files in Teamcenter automatically from NX. (after save operation)
I am aware that there is a dispatcher service for the same but am not sure if this is included in our current licenses.
Is there a way to find out?
Rushi
Re: NX drawing to PDF conversion
Hello All,
Datta Bmabal
Hello..
please give me solution.
Datta Bmabal
NX does not have the capability to provide pdf files directly on save.
The dispatcher services can be configured to create this using a workflow.
As a work around you can still manage to export the pdf file from NX directly to Teamcenter.
Refer attachment.
Cheers,
Rushi
Hello.  This question has been answered in a previous discussion.  Please see:
https://community.plm.automation.siemens.com/t5/Teamcenter-Administrators-Forum/NX-drawing-to-PDF/m-...
Thanks.
Patrick (Pat) Kennedy, Sr. PLM Application Engineer, Acuity Solutions
