NX manager Assy import and Naming convention
Hello Experts
This is my Assy/Part file on local disk, the Letter before *.prt is my revision
when i select the Assym for importing to TC this how the NXmanager is understanding
I want to import 083-00056-00-A.prt aprt from Native to Teamcneter as 083-00056-00/A instead of
083-00056-00-A/A, can you please help with the import setting i should be using
Also is there a way i can create the desired naming format in a text or exel and import the Part/Assy in that format (with Description and Part name attribute added)
Thanks in Advance
