NX - "Entire part reference set" not set after saving and reopening assembly
I'm relatively new to TC-NX integration support and now there is an issue in my organization.
There is a big assembly with a lot of sub assemblies. Some of the sub assemblies are in 'excluded reference set', where the user manually changes them to 'Entire part' whenever necessary and saves the assembly.
But the setting is not reflecting when the user reopens the assembly. The setting gets changed back to 'Model reference set' and need to be modified again. The user doesnot need this and wants it to be loaded with entire part reference.
I have tried some options but none of them are working, now I request this community if there is something you could help me with.
