NX10 integration to TC
Hi guys,
I've installed NX Manager on the server for my 2-tier client.
When I open NX from the RAC, I get an error about nx0tcin template not integrated.
Can you help?
Cem
Re: NX10 integration to TC
Hi guys,
I found it.
It was due to TC 10.1.0 do not recognize NX10 at the time of the installation.
It is said to be covered since TC 10.1.2 installation, or via manual installation of the feature called "nx0tcin.xml" by Teamcenter Environment Manager.
I've also attached it if anyone needs it.
