Naming rule for Dataset.object_name with counter
I need to create Naming Rule for a Dataset object_name property with counters. As I can found it's impossible?
Or I need use ITK (custom_exit) for USER_new_dataset_name?
The way with activating AE_dataset_with_id_usage preference not good for me
Re: Naming rule for Dataset.object_name with counter
I guess you need not write the user exit USER_new_dataset_name() bcoz you can specify the a naming rule in BMIDE and attach it to object_name.
And yes 'AE_dataset_with_id_usage' preference does not work during new dataset creation.
Keep posted about the way you achieved the result.
I can specify  rule, but the autogeneration for dataset object_name will not work  as I see. Assign button appear in dataset creation dialog only if dataset_id used
