Need advise for migration
I have a question about data migation tool.
Now the customer try to migrate the data in DB1 with the date in DB2.
*the data model in DB1 is different from the datamodel in DB2.
So now the currenty when I compare the data model in DB1 with the datamodel in DB2, the BOM line attribute defined for the Item Revision A in DB1 is different from the BOM line attribute defined for the Item Revision A in DB2.
I beleve that BOM line attribute is run time property and the BOM line attribute is not stored in DB.
So even though the BOM line attribtue defined in DB1 is different from the BOM line attribtue defined in DB2, there are no any impact during the migration. Is this correct?
Also if the number of the BOM line attribute defined in the Item in DB1 is different from the number of the BOM line attribute defined in the Item in DB2,  what is the attribute value of the BOM line attribute in DB2?
