Need an alternate for Find No in BOM
I want to Sort the BOM lines based on a custom property instead of "Find No"(bl_sequence_no). Could find a preference named "Property_Comparator" in the Siemens Preferences documentation. I've created the preference and added the value as suggested in the document (bl_item_object_desc=Lexicographical). But unfortunately it is not working. Has anyone faced the issue or is there any fix?
TC Version: 11.2
Re: Need an alternate for Find No in BOM
Make sure it's a site preference. Clear cache and then start the RAC. Should work with this, if it's not a bug.
BTW this was supposed to be fixed in 11.2: https://solutions.industrysoftware.automation.siemens.com/view.php?sort=desc&p=1&q=Property_Comparat...
Yes, I've created it as Site preference. Cleared the cache and all other possible. But it was not working as expected.
Not working in Structure Manager as well as in MPP.
Then I think GTAC should be contacted
