Need help for installing Teamcenter
I get an error while installing Teamcenter 11.2. I am using SQL server express edition. I have created a user and am succesfully logging in with management studio. But, teamcenter seems to not recognize credentials. Any suggestions what could be going wrong.
I am using named instance of the server.
Re: Need help for installing Teamcenter
Hello, for named instances, ensure that SQL browser service is running and port 1434 is not blocked by firewall
Thanks Arthur for taking your time to reply.
I changed the plan to install via default instance and port 1433. I used your response to ensure 1433 was not blocked by firewall. I then enabled tcp using sql server configuration. And finally it worked.
