Need help mapping NX attributes
Builder
Builder
Hi all.
I use below code for Nx weight and material attributes:
{ Dataset type="UGMASTER"
    # (hard-wired) DB_PART_NAME : "Part Name"
    # (hard-wired) DB_PART_DESC : "Part Description"
    DB_PART_RELEASE_DATE : date_released /master=iman  /description="Part Date Released"
    DB_PART_CREATION_DATE : Item.creation_date /master=iman /allow_null_value /description="DS Creation Date"
    Material:NR( UGPART-ATTR ).material /master=both /description="Material on UGPART-ATTR form"
    Weight:NR( UGPART-ATTR ).weight /master=both /description="Weight on UGPART-ATTR form"
Is it correct?
I've tried to changing the Material and weight in NX but nothing changed in TC side and attributes have not any value.
10 REPLIES 10
Re: Need help mapping NX attributes
What version of NX?
Jamie Griffis
Mercury Digital Services
Jamie Griffis | Teamcenter Architect | Applied CAx, LLC
Builder
Builder
Nx 11,
   Your example:
Material:NR(UGPART-ATTR ).material /master=both /description="Material on UGPART-ATTR form" Weight:NR( UGPART-ATTR ).weight /master=both /description="Weight on UGPART-ATTR form"
Try this:
NX_Material:NR(UGPART-ATTR).material /master=cad /description="Material on UGPART-ATTR form"
NX_Weight:NR(UGPART-ATTR).weight /master=cad /description="Weight on UGPART-ATTR form"
I don't think these can be /master=both but you can try it.
Jamie
Builder
Builder
Thanks it works. Is it possible to use this NX_Weight for Structure Manager weight roperty by just mapping attributes.
If needs BMIDE, could you please help me how?
You'd need to store the weight in an attribute on the Item Revision. Then you can display it in the BOM.
I think you'll need to create this attribute as a compound property.
In BMIDE, on your Item Revision create a new compound attribute to store the weight and name it however you wish. XY8_NX_Weight
Example of compound property path:
XY8_ItemRevision.IMAN_specification
     UGMASTER.ref_list
          UGPartMassPropsForm.mass
I just tested this and can confirm that it works.
Attribute mapping under UGMASTER:
"NX_Material" : NR(UGPART-ATTR).material /master=cad /description="Material on UGPART-ATTR form"
"NX_Weight" : NR(UGPART-ATTR).weight /master=cad /description="Weight on UGPART-ATTR form"
Compound property on ItemRevision business object (using BMIDE):
Created a block in NX and added a material (ABS):
Saved to Teamcenter - UGPART-ATTR (named reference form):
View > Properties on ItemRevision (based on compound property):
Finally, add bl_rev_a2_NX_Weight as a column to Structure Manager:
Regards, Ben
Builder
Builder
Thanks alot.
I did the procedure (add properties, deploy) but nothing added in Structure Manager fields.
Is there any other thing to do?
Hi @sma,
You are required to add the property in BOM Line object(Search in BMIDE for BOM Line) and traverse up to your custom property in BMIDE, then only it gets displayed in structure manager.
Or
Add the Custom object in the global constants Fnd0BomLineRevConfigProps.
Thanks.
Builder
Builder
Thanks @siemi
I've tried adding custom prop to Fnd0BomLineRevConfigProps but nothing changed. Would you think of any other reason preventing the new column to be shown in Structure Manager? It's confusing, cause the recipe is direct and simple but I cant get it working.
