Need help with property rendering on an ItemRev
Hello Community,
I'm struggeling with creating a property render - in this case:
On my item revision I created a compound property (xxx_Number_compoud) which 'gets' the value from an attached form.The property in the form is defined as an INTEGER property.
My property rendering XML looks like this:
<?xml version="1.0" encoding="UTF-8"?>
<icons Version="1.0">
    <propertyMap name="Renderer">
        <Item key="1" value="image1.png">
        <Item key="2" value="image2.png">
    </propertyMap>
    <primaryIcon source="ImageBasic.png">
        <overlayIcon source="xxx_Number_compound" mapName="Renderer">
        </overlayIcon>
    </primaryIcon>
</icons>
By using this renderer nothing happens ;-(
If I change the compound property that the property points to a STRING attribute everything is working fine.
Did anyone of you has an idea how to fix this isseu, maybe by using a cast like IntegerToString in the XML?
Thanks for your help
//Joerg
