Need to get uom_tag value of all the Items in our PS_BOM Report
How to get this uom_tag value in our report .
I could not find the XSL value to fetch this from Item properties.
Some of the similar property values
<xsl:variable name="itemID" select="$prtele/plm:UserData/plm:UserValue[@title='item_id']/@value"/>
<xsl:variable name="itemRev" select="$prtele/plm:UserData/plm:UserValue[@title='item_revision_id']/@value"/>
<xsl:variable name="itemName" select="$prtele/plm:UserData/plm:UserValue[@title='object_name']/@value"/>
<xsl:variable name="designID" select="/plm:PLMXML/plm:DesignRevision[@id='id']/@revision"/>
Please help me to get the report with Unit of Measure value of all Items
