No Flexlm license is available for Teamcenter optional module.
Hey,
I want to delete some of the legacy CAM Templates form TCRS 11.3.0 but I can't...
I changed License to our Partner one with lot more features for testing porpues but changed nothing.
From other side I prepared another environment in the same way as for us and This bug is not presenting...
Syslog Is saying the same...
Re: No Flexlm license is available for Teamcenter optional module.
I assume you changed SPLM_LICENSE_SERVER in TC_DATA\tc_profilevars.bat and restarted the Teamcenter environment. Further, I assume you've changed the local (client) SPLM_LICENSE_SERVER environment variable to match.
I also assume that you've deleted the NX dialog memory in C:\Users\<username>\AppData\Local\Siemens or reset it. After upgrading to NX 11 from a previous version.
File > Preferences > User Interface, Options > Reset Dialog Memory
Evaluating:AW 3.2
Perfect shotSmiley Wink
I am able to upload new CAM templates and now I am trying to setup a CAM mixed mode for my client.
The funny thing is that at some point we have to switch back to customer license file.....and the problem will ocurre again.
Is there a way to diagnose witch license is a couse of this bug?
Usually the FlexLM log will show which licenses are used or revoked.
Evaluating:AW 3.2
I checked the FLEX log file for any issues and we can find there a clear message.
Why TCRS 11.3 is checking this license module when I am trying to delete CAM Template file?
I found 2 entries on GTAC solution center about the same issue. Both under instigating.
Any clues?
Stefan_Pendl 3rd Gear
3rd Gear
For each Teamcenter CAM seat you also need a TCM55012 - NX CAM Embedded Client license.
Production: NX10.0.3, VERICUT 8.1, FBM, MRL 3.1.4 | TcUA 10.1 MP7 Patch 0 (10.1.7.0) | TcVis 10.1
Development: VB.NET, Tcl/Tk Testing: NX12.0 Preparing: NX12.0
