No business server instance is available. Try again later.
Hello Team,
I am facing above subjected error, while running 4T thin client
same error is coming in JBOSS cmd,
Pool manager is running absolutely fine and JBOSS is also starting,
after TC deployed msg something is going wrog and not able to track
I am pasting JBOSS server log below,
10:54:26,675 INFO [org.jboss.as.clustering.infinispan] (ServerService Thread Pool -- 31) JBAS010280: Activating Infinispan subsystem.
10:54:26,676 INFO [org.jboss.as.osgi] (ServerService Thread Pool -- 39) JBAS011940: Activating OSGi Subsystem
10:54:26,678 INFO [org.jboss.as.naming] (ServerService Thread Pool -- 38) JBAS011800: Activating Naming Subsystem
10:54:26,718 INFO [org.jboss.as.connector] (MSC service thread 1-1) JBAS010408: Starting JCA Subsystem (JBoss IronJacamar 1.0.7.Final)
10:54:26,754 INFO [org.jboss.as.naming] (MSC service thread 1-7) JBAS011802: Starting Naming Service
10:54:26,758 INFO [org.jboss.as.security] (ServerService Thread Pool -- 44) JBAS013101: Activating Security Subsystem
10:54:26,760 INFO [org.jboss.as.webservices] (ServerService Thread Pool -- 48) JBAS015537: Activating WebServices Extension
10:54:26,770 INFO [org.jboss.as.mail.extension] (MSC service thread 1-7) JBAS015400: Bound mail session [java:jboss/mail/Default]
10:54:26,778 INFO [org.jboss.as.security] (MSC service thread 1-8) JBAS013100: Current PicketBox version=4.0.6.final
10:54:26,796 INFO [org.jboss.as.connector.subsystems.datasources] (ServerService Thread Pool -- 27) JBAS010403: Deploying JDBC-compliant driver class org.h2.Driver (version 1.3)
10:54:26,971 INFO [org.jboss.ws.common.management.AbstractServerConfig] (MSC service thread 1-3) JBoss Web Services - Stack CXF Server 4.0.1.GA
10:54:27,156 INFO [org.apache.coyote.http11.Http11Protocol] (MSC service thread 1-3) Starting Coyote HTTP/1.1 on http-IZ18-PC-192.168.3.48-8080
10:54:27,324 INFO [org.jboss.as.remoting] (MSC service thread 1-5) JBAS017100: Listening on IZ18-PC/192.168.3.48:4447
10:54:27,324 INFO [org.jboss.as.server.deployment.scanner] (MSC service thread 1-7) JBAS015012: Started FileSystemDeploymentService for directory C:\Ganesh_Data\Softwares_Dumps\jboss-as-7.1.0.Final\standalone\deployments
10:54:27,330 INFO [org.jboss.as.remoting] (MSC service thread 1-2) JBAS017100: Listening on IZ18-PC/192.168.3.48:9999
10:54:27,416 INFO [org.jboss.as.connector.subsystems.datasources] (MSC service thread 1-6) JBAS010400: Bound data source [java:jboss/datasources/ExampleDS]
10:54:27,432 INFO [org.jboss.as.server.deployment] (MSC service thread 1-7) JBAS015876: Starting deployment of "tc.ear"
10:54:29,940 WARN [org.jboss.as.server.deployment] (MSC service thread 1-2) Class Path entry concurrent-1.3.2.jar in "/C:/Ganesh_Data/Softwares_Dumps/jboss-as-7.1.0.Final/bin/content/tc.ear/lib/jacorb.jar" does not point to a valid jar for a Class-Path reference.
10:54:29,942 WARN [org.jboss.as.server.deployment] (MSC service thread 1-2) Class Path entry antlr-2.7.2.jar in "/C:/Ganesh_Data/Softwares_Dumps/jboss-as-7.1.0.Final/bin/content/tc.ear/lib/jacorb.jar" does not point to a valid jar for a Class-Path reference.
10:54:29,946 INFO [org.jboss.as.server.deployment] (MSC service thread 1-4) JBAS015876: Starting deployment of "tc.war"
10:54:29,946 INFO [org.jboss.as.server.deployment] (MSC service thread 1-5) JBAS015876: Starting deployment of "JETIGateway-ejb.jar"
10:54:30,326 WARN [org.jboss.as.server.deployment] (MSC service thread 1-6) Class Path entry activation.jar in "/C:/Ganesh_Data/Softwares_Dumps/jboss-as-7.1.0.Final/bin/content/tc.ear/tc.war/WEB-INF/lib/jaxb-impl.jar" does not point to a valid jar for a Class-Path reference.
10:54:30,328 WARN [org.jboss.as.server.deployment] (MSC service thread 1-6) Class Path entry jaxb1-impl.jar in "/C:/Ganesh_Data/Softwares_Dumps/jboss-as-7.1.0.Final/bin/content/tc.ear/tc.war/WEB-INF/lib/jaxb-impl.jar" does not point to a valid jar for a Class-Path reference.
10:54:30,531 INFO [org.jboss.as.ejb3.deployment.processors.EjbJndiBindingsDeploymentUnitProcessor] (MSC service thread 1-5) JNDI bindings for session bean named Gateway in deployment unit subdeployment "JETIGateway-ejb.jar" of deployment "tc.ear" are as follows:
java:global/tc/JETIGateway-ejb/Gateway!com.teamcenter.jeti.ejb.Gateway
java:app/JETIGateway-ejb/Gateway!com.teamcenter.jeti.ejb.Gateway
java:module/Gateway!com.teamcenter.jeti.ejb.Gateway
java:jboss/exported/tc/JETIGateway-ejb/Gateway!com.teamcenter.jeti.ejb.Gateway
java:global/tc/JETIGateway-ejb/Gateway!com.teamcenter.jeti.ejb.GatewayLocalHome
java:app/JETIGateway-ejb/Gateway!com.teamcenter.jeti.ejb.GatewayLocalHome
java:module/Gateway!com.teamcenter.jeti.ejb.GatewayLocalHome
java:global/tc/JETIGateway-ejb/Gateway!com.teamcenter.jeti.ejb.GatewayHome
java:app/JETIGateway-ejb/Gateway!com.teamcenter.jeti.ejb.GatewayHome
java:module/Gateway!com.teamcenter.jeti.ejb.GatewayHome
java:jboss/exported/tc/JETIGateway-ejb/Gateway!com.teamcenter.jeti.ejb.GatewayHome
10:54:30,726 INFO [stdout] (MSC service thread 1-7) 2016/12/26-05:24:30,725 UTC MLD Log init: com.teamcenter.mld version V10000.1.0.40_20150421.00 (20150421)
10:54:30,729 INFO [stdout] (MSC service thread 1-7) log.properties found in the classpath
10:54:43,515 INFO [com.teamcenter.mld.jmx] (MSC service thread 1-7) 2016/12/26-05:24:43,514 UTC - IZ18-PC - getMBS: Had to create own: org.jboss.as.jmx.PluggableMBeanServerImpl@7a614724
10:54:48,572 INFO [com.teamcenter.mld.jmx.ConfigurationListener] (MSC service thread 1-7) 2016/12/26-05:24:48,572 UTC - IZ18-PC - accessing user preferences userNodeForPackage:com.teamcenter.mld.jmx
10:54:48,577 INFO [com.teamcenter.mld.jmx.ConfigurationListener] (MSC service thread 1-7) 2016/12/26-05:24:48,576 UTC - IZ18-PC - using configured preferences factory:null
10:54:48,601 INFO [stdout] (MSC service thread 1-7) ConfigurationListenerEntityResolver does not find the preferences.dtd so it will use the built-in copy instead.
10:54:48,634 INFO [stdout] (MSC service thread 1-7) ConfigurationListenerEntityResolver loads the internal preferences.dtd.
10:55:31,503 INFO [com.teamcenter.jeti.resourceadapter.spi.impl.ConnectionManagerImpl] (MSC service thread 1-7) None - 2016/12/26-05:25:31,502 UTC - IZ18-PC - Resource Adapter properties:
RetryLimit: 2
RetryDelay: 500
Max_Capacity: 500
Shrinking_Enabled: true
Inactivity_Timeout: 1800
Shrink_Frequency: 900
10:55:31,516 INFO [com.teamcenter.jeti.resourceadapter.spi.impl.ConnectionManagerImpl] (MSC service thread 1-7) None - 2016/12/26-05:25:31,516 UTC - IZ18-PC - Found the platform MBean server and registered the Resource Adapter pool configuration meban.
10:55:36,585 INFO [stdout] (MSC service thread 1-7) 2016/12/26-05:25:36,585 UTC MLD Log init: com.teamcenter.mld version V10000.1.0.40_20150421.00 (20150421)
10:55:36,606 INFO [stdout] (MSC service thread 1-7) log.properties found in the classpath
10:55:36,671 INFO [com.teamcenter.mld.jmx] (MSC service thread 1-7) 2016/12/26-05:25:36,671 UTC - IZ18-PC - getMBS: Had to create own: org.jboss.as.jmx.PluggableMBeanServerImpl@77aed99b
10:55:36,682 INFO [com.teamcenter.mld.jmx.ConfigurationListener] (MSC service thread 1-7) 2016/12/26-05:25:36,682 UTC - IZ18-PC - accessing user preferences userNodeForPackage:com.teamcenter.mld.jmx
10:55:36,684 INFO [com.teamcenter.mld.jmx.ConfigurationListener] (MSC service thread 1-7) 2016/12/26-05:25:36,684 UTC - IZ18-PC - using configured preferences factory:null
10:55:36,688 INFO [stdout] (MSC service thread 1-7) ConfigurationListenerEntityResolver does not find the preferences.dtd so it will use the built-in copy instead.
10:55:36,767 INFO [com.teamcenter.presentation.gateway.filters] (MSC service thread 1-7) None - 2016/12/26-05:25:36,767 UTC - IZ18-PC - DYNAMIC-RESPONSE-COMPRESSION set to: true
10:55:36,768 INFO [com.teamcenter.presentation.gateway.filters] (MSC service thread 1-7) None - 2016/12/26-05:25:36,768 UTC - IZ18-PC - DYNAMIC-RESPONSE-COMPRESSION-THRESHOLD (if compressing) set to: 500
10:55:36,769 INFO [com.teamcenter.presentation.gateway.filters] (MSC service thread 1-7) None - 2016/12/26-05:25:36,769 UTC - IZ18-PC - STATIC-RESPONSE-COMPRESSION set to: true
10:55:36,770 INFO [com.teamcenter.presentation.gateway.filters] (MSC service thread 1-7) None - 2016/12/26-05:25:36,770 UTC - IZ18-PC - STATIC-RESPONSE-COMPRESSION-CACHING set to: true
10:55:36,771 INFO [com.teamcenter.presentation.gateway.filters] (MSC service thread 1-7) None - 2016/12/26-05:25:36,771 UTC - IZ18-PC - STATIC-RESPONSE-COMPRESSION-THRESHOLD (if compressing) set to: 500
10:55:36,777 INFO [org.jboss.web] (MSC service thread 1-7) JBAS018210: Registering web context: /tc
10:55:36,779 INFO [org.jboss.as] (MSC service thread 1-7) JBAS015874: JBoss AS 7.1.0.Final "Thunder" started in 71158ms - Started 243 of 320 services (76 services are passive or on-demand)
10:55:36,803 INFO [org.jboss.as.server] (DeploymentScanner-threads - 2) JBAS018559: Deployed "tc.ear"
10:56:26,484 INFO [com.teamcenter.mld.jmx.ResponseTimeGaugeListener] (RTGaugeMonitor) 2016/12/26-05:26:26,484 UTC - IZ18-PC - -- Attr: FilterTimeAvg=0 (.LE. 80) : {com.teamcenter.mld:src=com.teamcenter.jeti.resourceadapter.spi.impl.ConnectionFactoryImpl,name=getConnection-ConnectionFactoryImpl,type=Collector,units=mSec}
10:57:55,770 INFO [com.teamcenter.presentation.gateway.login] (http-IZ18-PC-192.168.3.48-8080-1) 192.168.3.48.84895.Anonymous.00001 - 2016/12/26-05:27:55,770 UTC - IZ18-PC - User: null NOT logged in.
10:57:56,113 INFO [com.teamcenter.presentation.wae.internal.util.PerformanceInstrument] (http-IZ18-PC-192.168.3.48-8080-1) 192.168.3.48.84895.Anonymous.00001 - 2016/12/26-05:27:56,113 UTC - IZ18-PC -
<Performance type="Request">
<key id="RequestLabel" value="/tc/webclient" />
<key id="RemoteAddress" value="192.168.3.48" />
<event id="ForwardToJSP" beginTime="12/26/2016 10:57:55" endTime="12/26/2016 10:57:56" elapsed="339" />
<event id="_Total" beginTime="12/26/2016 10:57:55" endTime="12/26/2016 10:57:56" elapsed="345" />
</Performance>
10:58:01,357 INFO [org.jboss.ejb.client] (http-IZ18-PC-192.168.3.48-8080-1) JBoss EJB Client version 1.0.2.Final
10:58:36,795 INFO [com.teamcenter.mld.healthmonitoring.ConfigManager] (http-IZ18-PC-192.168.3.48-8080-1) 2016/12/26-05:28:36,795 UTC - IZ18-PC - Found monitoring config file: webtierMonitorConfig.xml
10:58:51,945 INFO [com.teamcenter.mld.healthmonitoring.ConfigManager] (http-IZ18-PC-192.168.3.48-8080-1) 2016/12/26-05:28:51,945 UTC - IZ18-PC - Found monitoring config info file: webtierMonitorConfigInfo.xml
10:58:55,716 INFO [com.teamcenter.mld.jmx.ResponseTimeGaugeListener] (RTGaugeMonitor) 2016/12/26-05:28:55,716 UTC - IZ18-PC - -- Attr: FilterTimeAvg=0 (.LE. 80) : {com.teamcenter.mld:src=com.teamcenter.soa.ptier.RestResponseHandler,name=SOA RestResponseHandler-RestResponseHandler,type=Collector,units=mSec}
10:58:55,734 INFO [com.teamcenter.mld.jmx.ResponseTimeGaugeListener] (RTGaugeMonitor) 2016/12/26-05:28:55,731 UTC - IZ18-PC - -- Attr: FilterTimeAvg=0 (.LE. 80) : {com.teamcenter.mld:src=com.teamcenter.soa.ptier.RestRequestTrigger,name=SOA RestRequestTrigger-RestRequestTrigger,type=Collector,units=mSec}
10:58:55,747 WARN [com.teamcenter.mld.jmx.ResponseTimeGaugeListener] (RTGaugeMonitor) 2016/12/26-05:28:55,747 UTC - IZ18-PC - ** Attr: FilterTimeAvg=347 (.GE. 100) : {com.teamcenter.mld:src=com.teamcenter.presentation.wae.mld.MLDIntegrationService,name=invoke-MLDIntegrationService,type=Collector,units=mSec}
10:58:55,746 INFO [com.teamcenter.mld.jmx.ResponseTimeGaugeListener] (RTGaugeMonitor) 2016/12/26-05:28:55,746 UTC - IZ18-PC - -- Attr: FilterTimeAvg=0 (.LE. 80) : {com.teamcenter.mld:src=com.teamcenter.soa.ptier.GatewayEjbAction,name=SOA GatewayEjbAction-GatewayEjbAction,type=Collector,units=mSec}
10:58:55,744 INFO [com.teamcenter.mld.jmx.ResponseTimeGaugeListener] (RTGaugeMonitor) 2016/12/26-05:28:55,743 UTC - IZ18-PC - -- Attr: FilterTimeAvg=0 (.LE. 80) : {com.teamcenter.mld:src=com.teamcenter.soa.ptier.SessionPostAction,name=SOA SessionPostAction-SessionPostAction,type=Collector,units=mSec}
10:58:55,743 INFO [com.teamcenter.mld.jmx.ResponseTimeGaugeListener] (RTGaugeMonitor) 2016/12/26-05:28:55,743 UTC - IZ18-PC - -- Attr: FilterTimeAvg=0 (.LE. 80) : {com.teamcenter.mld:src=com.teamcenter.soa.ptier.GatewayEjbAction,name=SOA JETI Time-GatewayEjbAction,type=Collector,units=mSec}
10:58:55,735 INFO [com.teamcenter.mld.jmx.ResponseTimeGaugeListener] (RTGaugeMonitor) 2016/12/26-05:28:55,732 UTC - IZ18-PC - -- Attr: FilterTimeAvg=0 (.LE. 80) : {com.teamcenter.mld:src=com.teamcenter.soa.ptier.SessionPreTrigger,name=SOA SessionPreTrigger-SessionPreTrigger,type=Collector,units=mSec}
10:58:56,110 INFO [com.teamcenter.mld.jmx.ResponseTimeGaugeListener] (RTGaugeMonitor) 2016/12/26-05:28:56,110 UTC - IZ18-PC - -- Attr: FilterTimeAvg=0 (.LE. 80) : {com.teamcenter.mld:src=com.teamcenter.presentation.gateway.filters.CompressionResponseStream,name=Write time-CompressionResponseStream,type=Collector,units=mSec}
10:58:56,112 INFO [com.teamcenter.mld.jmx.ResponseTimeGaugeListener] (RTGaugeMonitor) 2016/12/26-05:28:56,112 UTC - IZ18-PC - -- Attr: FilterTimeAvg=0 (.LE. 80) : {com.teamcenter.mld:src=com.teamcenter.presentation.gateway.filters.CompressionResponseStream,name=GZIP Write time-CompressionResponseStream,type=Collector,units=mSec}
10:58:56,126 INFO [com.teamcenter.mld.jmx.ResponseTimeGaugeListener] (RTGaugeMonitor) 2016/12/26-05:28:56,126 UTC - IZ18-PC - -- Attr: FilterTimeAvg=2 (.LE. 80) : {com.teamcenter.mld:src=com.teamcenter.presentation.gateway.filters.CompressionResponseStream,name=Flush time-CompressionResponseStream,type=Collector,units=mSec}
10:59:06,422 INFO [com.teamcenter.mld.jmx.ResponseTimeGaugeListener] (RTGaugeMonitor) 2016/12/26-05:29:06,422 UTC - IZ18-PC - -- Attr: FilterTimeAvg=0 (.LE. 80) : {com.teamcenter.mld:src=com.teamcenter.jeti.ejb.GatewayBean,name=invokeMethod-GatewayBean,type=Collector,units=mSec}
10:59:06,426 INFO [com.teamcenter.mld.jmx.ResponseTimeGaugeListener] (RTGaugeMonitor) 2016/12/26-05:29:06,426 UTC - IZ18-PC - -- Attr: FilterTimeAvg=0 (.LE. 80) : {com.teamcenter.mld:src=com.teamcenter.jeti.ejb.GatewayBean,name=authenticate-GatewayBean,type=Collector,units=mSec}
10:59:06,429 INFO [com.teamcenter.mld.jmx.ResponseTimeGaugeListener] (RTGaugeMonitor) 2016/12/26-05:29:06,429 UTC - IZ18-PC - -- Attr: FilterTimeAvg=0 (.LE. 80) : {com.teamcenter.mld:src=com.teamcenter.jeti.ejb.GatewayBean,name=hasAssignedServer-GatewayBean,type=Collector,units=mSec}
10:59:11,487 INFO [com.teamcenter.mld.jmx.ResponseTimeGaugeListener] (RTGaugeMonitor) 2016/12/26-05:29:11,487 UTC - IZ18-PC - -- Attr: FilterTimeAvg=0 (.LE. 80) : {com.teamcenter.mld:src=com.teamcenter.jeti.serverassigner.ServerAssigner,name=assign-ServerAssigner,type=Collector,units=mSec}
10:59:16,526 INFO [com.teamcenter.mld.jmx.ResponseTimeGaugeListener] (RTGaugeMonitor) 2016/12/26-05:29:16,525 UTC - IZ18-PC - -- Attr: FilterTimeAvg=0 (.LE. 80) : {com.teamcenter.mld:src=com.teamcenter.jeti.serveraccessor.ServerAccessor,name=invoke-ServerAccessor,type=Collector,units=mSec}
10:59:16,536 INFO [com.teamcenter.mld.jmx.ResponseTimeGaugeListener] (RTGaugeMonitor) 2016/12/26-05:29:16,536 UTC - IZ18-PC - -- Attr: FilterTimeAvg=0 (.LE. 80) : {com.teamcenter.mld:src=com.teamcenter.jeti.serveraccessor.ServerAccessor,name=authenticate-ServerAccessor,type=Collector,units=mSec}
10:59:37,239 INFO [com.teamcenter.mld.healthmonitoring.MonitoringNotification] (http-IZ18-PC-192.168.3.48-8080-1) 2016/12/26-05:29:37,239 UTC - IZ18-PC - getNotificationInfo types: 1
10:59:37,243 INFO [com.teamcenter.jeti.serveraccessor.ServerAccessor] (http-IZ18-PC-192.168.3.48-8080-1) 192.168.3.48.77477.Anonymous.00001 - 2016/12/26-05:29:37,242 UTC - IZ18-PC - Monitoring system disabled
10:59:37,245 WARN [com.teamcenter.jeti.serveraccessor.ServerAccessor] (http-IZ18-PC-192.168.3.48-8080-1) 192.168.3.48.77477.Anonymous.00001 - 2016/12/26-05:29:37,245 UTC - IZ18-PC - jetiORB parameter has not been initialized. Using JacORB
10:59:37,346 INFO [com.teamcenter.jeti.serveraccessor.ServerAccessor] (http-IZ18-PC-192.168.3.48-8080-1) 192.168.3.48.77477.Anonymous.00001 - 2016/12/26-05:29:37,346 UTC - IZ18-PC - ORB initialization Jumpstarted.
10:59:37,347 INFO [com.teamcenter.jeti.serverassigner.ServerAssigner] (http-IZ18-PC-192.168.3.48-8080-1) 192.168.3.48.77477.Anonymous.00001 - 2016/12/26-05:29:37,347 UTC - IZ18-PC - Looking for global pool configuration file: globalPoolConfig.properties
10:59:37,349 INFO [com.teamcenter.jeti.serverassigner.ServerAssigner] (http-IZ18-PC-192.168.3.48-8080-1) 192.168.3.48.77477.Anonymous.00001 - 2016/12/26-05:29:37,349 UTC - IZ18-PC - Found global pool configuration file /globalPoolConfig.properties in classpath
10:59:37,350 INFO [com.teamcenter.jeti.serverassigner.ServerAssigner] (http-IZ18-PC-192.168.3.48-8080-1) 192.168.3.48.77477.Anonymous.00001 - 2016/12/26-05:29:37,350 UTC - IZ18-PC - Looking for TreeCache configuration file: TreeCacheTCP.xml
10:59:37,351 INFO [com.teamcenter.jeti.serverassigner.ServerAssigner] (http-IZ18-PC-192.168.3.48-8080-1) 192.168.3.48.77477.Anonymous.00001 - 2016/12/26-05:29:37,351 UTC - IZ18-PC - Found TreeCache configuration file /TreeCacheTCP.xml in classpath
10:59:42,456 INFO [org.jboss.cache.PropertyConfigurator] (http-IZ18-PC-192.168.3.48-8080-1) Found existing property editor for org.w3c.dom.Element: org.jboss.util.propertyeditor.ElementEditor@67f51815
10:59:42,461 INFO [org.jboss.cache.PropertyConfigurator] (http-IZ18-PC-192.168.3.48-8080-1) attribute size: 15
10:59:42,500 INFO [com.teamcenter.jeti.SharedStore] (http-IZ18-PC-192.168.3.48-8080-1) 192.168.3.48.77477.Anonymous.00001 - 2016/12/26-05:29:42,500 UTC - IZ18-PC - TreeCache Configuration:
TreeCache Cluster Name=Cluster
TreeCache Mode=TCP
Local Service Port=17810
TreeCache Socket Connect Timeout=2000
TreeCache Peers=localhost[17800]
TreeCache Port Range=1
TreeCache Connection Timeout=30000
TreeCache Merge Min=5000
TreeCache Merge Max=10000
TreeCache Join Timeout=60000
10:59:42,535 INFO [org.jgroups.JChannel] (http-IZ18-PC-192.168.3.48-8080-1) JGroups version: 2.4.1
10:59:42,626 INFO [org.jgroups.blocks.ConnectionTable] (DownHandler (TCP)) server socket created on 192.168.3.48:17810
10:59:42,627 INFO [stdout] (UpHandler (GMS))
10:59:42,627 INFO [stdout] (UpHandler (GMS)) -------------------------------------------------------
10:59:42,627 INFO [stdout] (UpHandler (GMS)) GMS: address is 192.168.3.48:17810
10:59:42,628 INFO [stdout] (UpHandler (GMS)) -------------------------------------------------------
10:59:42,635 INFO [org.jgroups.blocks.ConnectionTable] (DownHandler (TCP)) created socket to 127.0.0.1:17800
10:59:42,639 INFO [org.jgroups.blocks.ConnectionTable] (DownHandler (TCP)) created socket to 192.168.3.48:17800
10:59:42,696 INFO [org.jboss.cache.TreeCache] (UpHandler (STATE_TRANSFER)) viewAccepted(): [192.168.3.48:17800|1] [192.168.3.48:17800, 192.168.3.48:17810]
10:59:42,701 INFO [com.teamcenter.jeti.SharedStore] (UpHandler (STATE_TRANSFER)) None - 2016/12/26-05:29:42,701 UTC - IZ18-PC - TreeCache View: [192.168.3.48:17800|1] [192.168.3.48:17800, 192.168.3.48:17810]
10:59:42,702 INFO [org.jboss.cache.TreeCache] (http-IZ18-PC-192.168.3.48-8080-1) TreeCache local address is 192.168.3.48:17810
10:59:42,702 INFO [com.teamcenter.jeti.SharedStore] (http-IZ18-PC-192.168.3.48-8080-1) 192.168.3.48.77477.Anonymous.00001 - 2016/12/26-05:29:42,702 UTC - IZ18-PC - TreeCache GMS address: 192.168.3.48:17810
10:59:45,701 ERROR [org.jgroups.protocols.FD_SOCK] (DownHandler (FD_SOCK)) received null cache; retrying
10:59:46,209 INFO [org.jgroups.blocks.ConnectionTable] (DownHandler (TCP)) created socket to 192.168.3.48:17810
10:59:46,280 INFO [org.jboss.cache.TreeCache] (http-IZ18-PC-192.168.3.48-8080-1) received the state (size=1024 bytes)
10:59:46,302 INFO [org.jboss.cache.TreeCache] (http-IZ18-PC-192.168.3.48-8080-1) received the state (size=1024 bytes)
10:59:46,308 INFO [org.jboss.cache.TreeCache] (http-IZ18-PC-192.168.3.48-8080-1) received the state (size=1024 bytes)
10:59:46,312 INFO [org.jboss.cache.TreeCache] (http-IZ18-PC-192.168.3.48-8080-1) received the state (size=1024 bytes)
10:59:46,319 INFO [org.jboss.cache.TreeCache] (http-IZ18-PC-192.168.3.48-8080-1) received the state (size=1024 bytes)
10:59:46,329 INFO [org.jboss.cache.TreeCache] (http-IZ18-PC-192.168.3.48-8080-1) received the state (size=1024 bytes)
10:59:46,334 INFO [org.jboss.cache.TreeCache] (http-IZ18-PC-192.168.3.48-8080-1) received the state (size=1024 bytes)
10:59:46,344 INFO [org.jboss.cache.TreeCache] (http-IZ18-PC-192.168.3.48-8080-1) received the state (size=1024 bytes)
10:59:46,389 INFO [com.teamcenter.jeti.serverassigner.ServerAssigner] (http-IZ18-PC-192.168.3.48-8080-1) 192.168.3.48.77477.Anonymous.00001 - 2016/12/26-05:29:46,389 UTC - IZ18-PC - Global pool configuration:
SOFT_TIMEOUT_EDIT=28800
PROCESS_MAX_PER_USER=0
SOFT_TIMEOUT_STATELESS=1200
CACHE_CONFIG_PATH=TreeCacheTCP.xml
HARD_TIMEOUT_STATELESS=28800
QUERY_TIMEOUT=0
HARD_TIMEOUT_EDIT=28800
SOFT_TIMEOUT_READ=28800
HARD_TIMEOUT_READ=28800
USER_TIMEOUT_STATELESS=0
ASSIGNMENT_TIMEOUT=60
10:59:46,390 INFO [com.teamcenter.jeti.serverassigner.ServerAssigner] (http-IZ18-PC-192.168.3.48-8080-1) 192.168.3.48.77477.Anonymous.00001 - 2016/12/26-05:29:46,390 UTC - IZ18-PC - Global pool config published.
11:00:01,611 INFO [com.teamcenter.presentation.gateway.login] (http-IZ18-PC-192.168.3.48-8080-1) 192.168.3.48.77477.Anonymous.00001 - 2016/12/26-05:30:01,611 UTC - IZ18-PC - User: infodba NOT logged in.
11:00:01,615 WARN [com.teamcenter.presentation.webclient.actions] (http-IZ18-PC-192.168.3.48-8080-1) 192.168.3.48.77477.Anonymous.00001 - 2016/12/26-05:30:01,615 UTC - IZ18-PC - No business server instance is available. Try again later. If this problem persists, please contact the system administrator.
11:00:01,619 INFO [com.teamcenter.presentation.wae.internal.util.PerformanceInstrument] (http-IZ18-PC-192.168.3.48-8080-1) 192.168.3.48.77477.Anonymous.00001 - 2016/12/26-05:30:01,619 UTC - IZ18-PC -
<event id="ForwardToJSP" beginTime="12/26/2016 11:00:01" endTime="12/26/2016 11:00:01" elapsed="3" />
<event id="_Total" beginTime="12/26/2016 10:58:01" endTime="12/26/2016 11:00:01" elapsed="120307" />
</Performance>
11:00:26,502 WARN [com.teamcenter.mld.jmx.ResponseTimeGaugeListener] (RTGaugeMonitor) 2016/12/26-05:30:26,502 UTC - IZ18-PC - ** Attr: FilterTimeAvg=110023 (.GE. 100) : {com.teamcenter.mld:src=com.teamcenter.jeti.resourceadapter.spi.impl.ConnectionFactoryImpl,name=getConnection-ConnectionFactoryImpl,type=Collector,units=mSec}
11:00:56,460 INFO [com.teamcenter.mld.jmx.ResponseTimeGaugeListener] (RTGaugeMonitor) 2016/12/26-05:30:56,460 UTC - IZ18-PC - -- Attr: FilterTimeAvg=0 (.LE. 80) : {com.teamcenter.mld:src=com.teamcenter.jeti.resourceadapter.spi.impl.ConnectionImpl,name=invokeMethod-ConnectionImpl,type=Collector,units=mSec}
11:00:56,464 INFO [com.teamcenter.mld.jmx.ResponseTimeGaugeListener] (RTGaugeMonitor) 2016/12/26-05:30:56,464 UTC - IZ18-PC - -- Attr: FilterTimeAvg=0 (.LE. 80) : {com.teamcenter.mld:src=com.teamcenter.jeti.resourceadapter.spi.impl.ConnectionImpl,name=authenticate-ConnectionImpl,type=Collector,units=mSec}
Re: No business server instance is available. Try again later.
Any Solution for the above issue?
Did you try to login after this error? Because, I too faced the same, my first request used to fail, but on retrying it worked. Also on the server, check in Task Manager if tcserver.exe task is running. And there should be minimum 3 of these processes running.
Try running server manager in a console, rather than as a service.
We need to see if the issue is with Jboss to connect with Pool Manager or if the Pool manager itself is having problems. Check in Task Manager where the Pool Manager is running or in the JMX console for tcserver processes. There should be 3 tcservers running. With this we can assume that the Pool Manager is running and we may need to look the connectivity between JBoss and Pool Manager.
Meanwhile in your logs I see some warnings/errors based on some classpath variable. Its not clear to me just looking at the logs, but seems its unable to identify some binaries based on the class path..you may probably need to look there and see if you can find any more details on that.
LN
I receive the same error.
1. TC worked when first installed.
2. After an "upgrade" to Microsoft Windows 10, I started to get a request for my enterprise password. This went on for several weeks.
3. Starting yesterday (10/15/18), a TC window popped up asking for my server username. What would this be---a separate Teamcenter-specific username? Not knowing this, I enter my enterprise username and password, and now my login is unsuccessful.
Previously, TC just opened up, and now this. Anyone know a workaround?
What do you recommend for a non-superuser?
