cancel
No listener error
Hi guys,
         First thanks for you all for the support given to me..Now i am in need of to make our production server work.Due to unexpected reboot,our server occurs some error.When i checked ,I able to understand,Database and teamcenter applicatrion are fine,But the listener which creates the problem.I have tried various suggestion give in google i.e creating a new listener,checking listener.ora,tnsnames,ora files etc.But nothing is working.So please give me a suggestion to overcome this issue.
I have listed all my files here for you guys reference.
LISTENER.ORA
# listener.ora Network Configuration File: C:\APLM\app\infodba\product\11.2.0\dbhome_1\network\admin\listener.ora
# Generated by Oracle configuration tools.
SID_LIST_LISTENER =
(SID_LIST =
(SID_DESC =
(SID_NAME = CLRExtProc)
(ORACLE_HOME = C:\APLM\app\infodba\product\11.2.0\dbhome_1)
(PROGRAM = extproc)
(ENVS = "EXTPROC_DLLS=ONLY:C:\APLM\app\infodba\product\11.2.0\dbhome_1\bin\oraclr11.dll")
LISTENER =
(DESCRIPTION_LIST =
(DESCRIPTION =
(ADDRESS = (PROTOCOL = TCP)(HOST = TEAMCENTER.amwasia.com)(PORT = 1521))
ADR_BASE_LISTENER = C:\APLM\app\infodba
TNSNAMES.ORA
# tnsnames.ora Network Configuration File: C:\APLM\app\infodba\product\11.2.0\dbhome_1\network\admin\tnsnames.ora
PEP =
(DESCRIPTION =
(CONNECT_DATA =
(SERVER = DEDICATED)
(SERVICE_NAME = PEP)
TCRA =
(DESCRIPTION =
(CONNECT_DATA =
(SERVICE_NAME = TCRA)
ORACLR_CONNECTION_DATA =
(DESCRIPTION =
(ADDRESS_LIST =
(ADDRESS = (PROTOCOL = IPC)(KEY = EXTPROC1521))
(CONNECT_DATA =
(SID = CLRExtProc)
(PRESENTATION = RO)
SQLNET.ORA
# This file is actually generated by netca. But if customers choose to
# install "Software Only", this file wont exist and without the native
# authentication, they will not be able to connect to the database on NT.
SQLNET.AUTHENTICATION_SERVICES = (NONE)
While i tried to ping tnsping PEP
it returned no listener error..
Expecting replies...
Thank you
Re: No listener error
when i start listener using lsnrctl start command,I am getting listener laready running and
TNS-12560 and TNS-00530 error.
PFA.
