No previous dataset?
Honored Contributor
Honored Contributor
I was looking for a previous dataset for an NX part, and the search came up empty.  I tried a different number, thinking it was operator error, but I had success then.  I know the item/item revision exit, but why no previous datasets?
Originally we had Teamcenter set to save 3, but that was bumped up to 5....could it be set to 0 for this particular dataset?  and if so, how would I change that?
-Dave
7 REPLIES 7
Re: No previous dataset?
Did you try searching in General search
Honored Contributor
Honored Contributor
General search only shows only the Item Master, no previous datasets.
-Dave
Good afternoon, maybe I did not fully understand you when you select a data set in Teamcenter and open File -> Open With ... in the drop-down list you do not have previous versions of the data sets?
Honored Contributor
Honored Contributor
I do using that method, but not if I do a dataset search.  Strange.
-Dave
Check the preference QRY_dataset_display_option. A value of 1 will show all versions while a value of 2 will only show the latest version.
Evaluating: AW 3.4
Honored Contributor
Honored Contributor
Confirmed, it is set to 1 for me.  I can also search for, and find older datasets for other parts, just this one was giving me trouble.
-Dave
I would have suggested that someone had "Purged" the additional versions, which can happen in a workflow when releasing, or through the rich client interface (Edit > Purge), but you are able to see more versions using File > Open With... so the DS versions have not been purged.
Which means there is some kind of Access issue with the other versions of this DS somehow. You can try the same search logged in as infodba to see if its access related. I would call GTAC at this point.
Evaluating: AW 3.4
