No server pool is registered in the treecache cluster
Hello all,
I attached a screenshot of what I see when trying to log into teamcenter. It was working previously, but I had to change some config files to get combatibility with shop floor connect. I will be back tracking my steps to figure out what I changed that caused this error so I can correct it and move forward with my testing. To save some time what I ask is, has anyone seen this error before? And if so, how did you go about resolving this?
As always, many thanks
Re: No server pool is registered in the treecache cluster
The web tier is not able to talk to server (pool) manager. Check your ports and server names. SFC has a lot of J2EE components that may have introduced a port conflict.
Evaluating: AW 3.4
Hey Randy, thanks for the info. The correct port was 7001 while we were using 8080. And after some JBoss restarts and changes to the files we were able to log into teamcenter.
