Not able to select Signoff in workflow for Review task
I have a workflow where there are 3 consecutive Review Tasks at the start of the workflow.
I am able to select Signoff user for 1st Review Task only and not for the 2nd and 3rd task.
The thing I required is, users is approving 1st Review Task should have the task in worklist to select User for 2nd Review and similarly for the next Review Task.
How to achieve this?
Hrishikesh
3 REPLIES 3
Re: Not able to select Signoff in workflow for Review task
@Hrishikesh - look at the EPM-auto-assign-rest handler. You can place it at a specific task and have the process owner of that task then assign the next tasks.
https://docs.plm.automation.siemens.com/tdoc/tc/12.1/help#uid:xid1256819:index_workflow_designer:id2...
Jamie Griffis | PLM Solution Architect | Engineering USA
Hi @Jamie_Griffis ,
I tried your suggestion but somehow not able to do it.
Here is my workflow where there are almost all the review tasks.
I have tried to add EPM-auto-assign-rest handler on Parent task and Select-signoff task but not achieved what I want.
Could you please help me where exactly I have to add handlers?
Hrishikesh
Hi @Jamie_Griffis
Actually the issue is resolved. There was EPM-auto-assign-rest handler at the Start of the workflow without any argument. So it was not allowing other users to select signoff user.
So I removed it and then checked the workflow works fine now as per my requirement.
Hrishikesh
