Number of version of dataset
Hi everybody,
I would know how to configure the number of version TC keep for each dataset?
Thank you
PLM Technical IT
Re: Number of version of dataset
It is a preference.I'm in TC10.1.3.1a - look at AE_dataset_default_keep_limit , by default it is 3. Be very careful when changing this setting. You may not want to keep 10 files of each dataset if your company generates a lot of datasets and you'd need a lot of volume space.
Jamie
thank you, it is the same in TC 8.3.
I thinked we can remove for some datasets the parameters but it's impossible.
Thank you
PLM Technical IT
