OOTB group with only reading access
Is any of the groups existing in TC (not the customized ones) that can be used for used to read but avoiding any modification (deleting, modifying structure...) by miskate?
Re: OOTB group with only reading access
There are no read-only group/roles. You'll need to create one.
Evaluating: AW 3.4
Ok. Thank you Randy!
