OTW NXwindows Install Path
Builder
Builder
Is there a way we can use NX env variable instead of hardcoding the NX install Path in OTW parameters, in my company users have installed NX  (9.5)in diff path and i dont want to reinstall till we migrate to next NX version
%UGII_BASE_DIR%
Re: OTW NXwindows Install Path
Nope. A common path is required. Good job not installing it in the default location which contains spaces. Nice short path name.
Evaluating: AW 3.4
Builder
Builder
Thnaks Randy, one more lesson that i learned is for the NX version we need to add NX29.0 "Zero" we missed and endup troubleshooting spending lot of time
You are right. I didn't catch that in your screenshot. V29.0 is required for NX 11.
Evaluating: AW 3.4
