OTW install error
Hello All
When I use otw installation,I got this error messenage
Where I can check setting?
Thanks.
Best regards
Best Regards
David
Teamcenter 11.4,Active Workspace 3.4
Solid Edge ST10
8 REPLIES 8
Re: OTW install error
Good afternoon, verify that the Distributor and RMI services are running on tcotw. Also check that port 12099 is not blocked by the firewall.
Besides 12099, you probably want to specify exceptions in the firewall for the other two ports also...
https://community.plm.automation.siemens.com/t5/Teamcenter-Users-Forum/TC-11-2-4-Tier-Client-Install...
Evaluating: AW 3.4
Hello
I already close all firewall for this machine.
I start RMI and Server
I seen OK.
But I still can't link port:120991.PNG2.PNG
And it shows me that can't find dissserverstandce in the disserver at twotw:12099
where I need to check next?
Best Regards
David
Solid Edge ST10
Looks like you used ports 12099, 12098 and 12097. Try disabling the firewall temporarily on the server then start RMI followed a few seconds later by the Distribution Server. When these scripts are converted to services there is a dependency created where RMI must be started first.
On the client, launch IE with admin rights then connect to the web tier address where you deployed the Distribution Server Instance. e.g. http://webapplicationserver:8080/distributionserverinstancename/otw.html (your actual http address may vary).
Evaluating: AW 3.4
Hello
Best Regards
David
Solid Edge ST10
Did you disable the firewall first before trying?
Evaluating: AW 3.4
Hello;
All of experts are here so it is hard to add anything. I just was thinking of time synchronization ....
Hello JFK1963,Randy Ellsworth
I change disserver and disserverstandce file from E: to C: ,and reinstall that.
And it's working.
But I still don't know why....
I install TC main files in E:,and it works fine.....
Thank you all.
Best Regards
David
Solid Edge ST10
