One Step Command Labels - AWC
Hi All,
I am looking for possible solution for below requirement . Please let me know if anyone have worked on similar requirement.
User need to click “Lables (…)” one step command each time after login to see the command’s display name.
Requirement: By default, the Labels should be enabled. It should show the command's display name by default.
Attached the image for the reference
Re: One Step Command Labels - AWC
Hi @456  ,
Please check below link , may be it helps you to create a new command button.
https://docs.plm.automation.siemens.com/tdoc/aw/4.0/aw_html_collection#uid:xid1378894
Best Regards
Gurkan
