Open Dataset with extend batch
I had create a new dataset type for .mp4 file, I wanna use a media player to open it when it doule-click it in teamcenter.
I tried to reference the below link to do it, but it doesn't work. All of them ask me to associate the file type at system level, but I don't want to associate the file type.
Any idea about it?
Thank you.
https://solutions.industrysoftware.automation.siemens.com/view.php?sort=desc&q=tc+dataset+bat&file_t...
https://solutions.industrysoftware.automation.siemens.com/view.php?sort=desc&q=tc+dataset+bat&p=2&fi...
https://solutions.industrysoftware.automation.siemens.com/view.php?sort=desc&q=tc+dataset+bat&p=3&fi...
Re: Open Dataset with extend batch
Teamcenter passes the file to the operating system and the operating system determines which app to open with based on the extension. If you want to run movies by double-clicking the dataset in Teamcenter then you'll have to define the extension and associate an application in the operating system.
Evaluating:AW 3.2
It meen whatever I set in Shell/symbol, win luanch command, and tool action, it always determines with OS? Or I misunderstand something with tools?
On Windows, that is correct. You have more control on Linux.
Evaluating:AW 3.2
I create a new mime type for tools, and it use open command to a batch.
Maybe on windows, it was the most easy to achieve the function I want.
