Order ProductViews
We're using Teamcenter 11.4 (mp10).
On some Process Revision, we're creating Product Views.
I'd like to understand how these Product Views are "ordered".
For example, if I create some product views A,B,C,D,.. one after another I'm getting :
Consequently it feels like they're ordered in the creation order or in the alphabetical order.
Yet in a object summary I get :
I'm not understanding the logic.
I care about this order as you retrieve this one in the Electronic Work Instruction viewer :
So I'd like to understand how they're ordered and to know whether it's possible to change this order once the product views are created.
Thanks in advance for any help ! :)
Best regards,
Frédéric.
4 REPLIES 4
Re: Order ProductViews
Good afternoon, try changing the value
Edit-> Options ...-> UI -> Tree displaying order
Hello @ArthurRM,
Thank you for your advice !
Indeed this changes the display in the RAC.
However, I do not see any change in the AW client (although I'm identified with the same user so the preference might apply). It seems that Product View display in the "Not ordered" order.
Do you have more data on this order ? How is it defined ?
Best regards,
Frédéric.
Unfortunately, at the moment we don’t use AWC so it’s hard for me to say something to you. It is possible that other users who use AWC will be able to help you.
No problem @ArthurRM, thank you for your answer !
Yes, that's why I'm hopping !
