Over the Web Teamcenter Installation (OTW)
While installing the OTW client.. im facing the blow issues..
Unable to launch Over-the-Web Installer due to one or more of the following reasons...
The required Java Plug-in (Version 1.7 or higher) is missing, check here to get the Java Plug-in.
The browser and Java Plug-in mismatch. 32-bit browser requires 32-bit Java Plug-in, 64-bit browser requires 64-bit Java Plug-in.
The browser has Java disabled.
Need solution..
​Regards…….
Velayutham S
Mobile: +91 9600137232.
Re: Over the Web Teamcenter Installation (OTW)
Take a look at this post.
Arden Bedell | Teamcenter Wonk | Applied CAx, LLC
Assuming you are installing on a 64-bit machine, your browser and java bit versions need to match.
Can you give us some more details on your Teamcenter, java, machine, browser to understand your problem better?
Harish
Thanks for the support..!!
I tired below steps.. but unbale to run the OTW installation.
1. Installed 64 bit Java & IE ( both is same).
2. Java Script is enabled.
3. In the java->security-> otw Url added..
​Regards…….
Velayutham S
Please check and see if java 64-bit (you referred below) is the first entry in the PATH environment variable.
If not, open a command shell on the machine, include 64-bit java in the path variable (first entry) and then relaunch the OTW through the shell.
Let us know how it goes
Harish
Me too faced this issue and finally we adopted a process of OTW installation without using Browser. Here is the post
you can give a try.
Phani
OTW installation is your requirement.
​Regards…….
Velayutham S
I got solutions for the OTW issues,
Problem: Dont know which bit IE is run in the installing time .
Solution: Run IE enable.exe or manuly edit in regedit
  1. Run IE64Enable.exe or In regedit create manual entery HKEY_LOCAL_MACHINE (or HKEY_CURRENT_USER)\SOFTWARE\Microsoft\Internet Explorer\Main\
New--> DWORD(32 BIT)-->NAME IS -->TabProGrowth
​Regards…….
Velayutham S
If you run internet Explorer as administrator, i think no need to modify the registry as well.
May be..
Some of group pollicy is blcoking in some of org.
​Regards…….
Velayutham S
