Override "Open File on Double-click" function on Dataset ?
I have a custom Java plugin which runs with a custom toolbar/right click menu on Dataset and opens the files in another application.I want the same plugin to execute if I double click the dataset.
Is this achievable ?
As there are additional metadata to be exported along with the file to load in another application, the OOTB functionality of defining a custom tool cannot be used in this case.
