Own item in New Item command pane
I created my own item type in Teamcenter Rapid Start 10.1.4 (in MBIDE and deployed).
In the New Item command pane are only few objects. How to add my own to these?
4 REPLIES 4
Re: Own item in New Item command pane
Are you sure you've added your item and deployed it to the database successfully?
If yes, did you try to delete the cache in the client and try it again?
Or log into the server as info dba and check that again?
Cem
Hello JuRAJ,
 I also face that problem in Rapid Start.... yet it not resoled .
so,u should go thruogh the Patch you will get a result.....U want to update the TcRS..
Spoiler
Hi Cem,
You'r right.
After server restart I loged as infodba and the Item is there. Also under logino of other person.
So it works fine, just need restart.
Did you make a live deploy?
This generally happens after a live deploy.
Alao sometimes after that you may need to clean your client's cache.
