PDF generation after workflow validation
I would like to know how to create a PDF automatically every time a document is approved through a workflow in TC.
Thank you in advance,
Laura
3 REPLIES 3
Re: PDF generation after workflow validation
Laura,
What version of TC? What type of documents?
~Jamie
Jamie Griffis | Teamcenter Architect | Applied CAx, LLC
Hi Jamie,
It's TC 11.3 and my intention is to generate a PDF from a word dataset for
example.
Thank you,
Laura Torrens
Do you have dispatcher set up and functional? If not, you need to to set that up first.
Look at the DOCMGT-render-document-revision handler and https://solutions.industrysoftware.automation.siemens.com/result.php?sort=desc&q=create+pdf+dispatch...
Jamie
