PDPS 12.1 fresh install association error in Admin console
I have done a fresh server set up with Oracle 11g Release 2 (11.2.0.4) and Technomatix 12.1
the last step is to associate the schema under EMserver Admin. the associaction was good but then i recive this error.....any one  have any knowledge of this error I have checked and double checked the COM and DCOM setttings. image1.JPG
Re: PDPS 12.1 fresh install association error in Admin console
I have figured it out, it has t do with the Com identity just in case somone was having this issue
Hi, can you explain me in more detail, how did you solved it exactly? i have the same problem :/
