PMM URL - what is it?
Hi!
I need to use Design-Part alignment and publishing with TC 11.3. During the installation process TEM ask me for PMM URL. I have no idea what I will put in this field.
In the documentation I find that:
PMM URL specifies the URL of the Product Master
Management Web tier end point. Type a URL
of the following format:
http://host:port/tc/tcbompost/tcbompostwebservice
This value is used to populate a
UsageWC_Endpoint database preference.
but the are no exploration what is the Product Master Management Web tier. I put the random URL to this field. As result the CAD-BOM Alignment perspective do not starting properly. The error message is attach to this post.
Please help.
Re: PMM URL - what is it?
Siemens Creator
Are you installing CAD-BOM Alignment? That solution is used when you want to integrate Teamcenter (UA) with Teamcenter PMM.
If you "just" want to do CAD Part alignment between designs and parts in Teamcenter RAC you don't really need to install anything. It's already there in applications like MSM/MBM & MPP.
Check the menu Tools | Structure Alignment in these applications.
